- 1 Sep 2016
My old Dell Inspiron 17 7000 - 7737 has a few screen problems and been replaced 4 times , Dell have told me they will give me a free replacement but not sure which machine to choose from , i have 2 choices , which 1 would you choose from ?
Choice 1
Inspiron 17 7000 Series – 7778
6th Generation Intel Core i7-6500U Processor (4M Cache, up to 3.10 GHz)
17.3-inch FHD (1920 x 1080) Truelife LED-Backlit Touch Display with Wide Viewing Angles
16GB (2x8G) 2133MHz DDR4 Memory
512GB Solid State Drive
nVidia MX 940 Discrete GFX, 2GB GDDR5 Graphics
802.11ac + Bluetooth 4.2, Dual Band 2.4&5 GHz, 1x1
Internal UK/Irish Qwerty Backlit Keyboard
65W AC Adapter with UK Irish Power Cord
56 WHr, 4-Cell Battery (integrated)
Choice 2
Inspiron 15 7000 - 7559
6th Generation Intel® Core™ i7-6700HQ Processor (6M Cache, up to 3.50 GHz)
15.6-inch UHD (3840 x 2160) Truelife LED- Backlit Touch Display
16GB Dual Channel DDR3L 1600MHz (8GBx2)
128GB SSD [128GB Solid State Drive]
1TB 5.4k HDD [1TB 5400 rpm Hard Drive]
NVIDIA® GeForce® GTX 960M 4GB GDDR5
Intel® 3165AC + BT4.0 [802.11ac + Bluetooth 4.0, Dual Band 2.4&5 GHz, 1x1]
Thank you
Choice 1
Choice 2
Thank you
