Which route should I go with?
26 Dec 2013
404 Not Found
I am just planning my new loop. Using an existing Ax240 rad and a new 360 rad in the Fractal Define S case..
Some quick drawings of possible loops, any thoughts?
Or
Looks good to me, although you want the loop from pump to GPU to extend to both GPUs otherwise no water will actually move around the top block it'll just pass straight through.
I'd go with the second one, but I'd probably do the GPU's in parallel rather than in series.
Also, depending on the res, you should be able to go into the top of it rather than needing to loop to the bottom.
Yeah, was deff going to go parallel, just a **** up on the drawing (was originally running the loop the other way round so would have been parallel).
Are you piping between your gfx cards or using a bridge?
If pipe I'd recommend putting them in parallel.
