Which router to go for?
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
I'm looking at buying a router for the new place I'll be moving into, its around 45m2.
Home connection
ISP:
Orange
Type: FTTP with ONT
Speeds: 300Mb/s Up and 50Mb/s Down (Might go for the 1Gb/s in the near future)
Router Requirements
- PPoE & VLAN Support
- WireGuard Server functionality
- Remote Access
Budget: £120 (For the home router)
I'm currently considering the GL.iNet Flint 2 (GL-MT6000) or the older Flint (GL-AX1800), which would easily allow me to setup a WireGuard Server and Client using another router such as Slate Plus (GL-A1300). Is this the best combo, or are there better options?
For the price point I can’t see you going wrong with the Flint 2.
Do you've the Flint 2? I read about WiFi issues, not sure if the extra £30 is worth it for the Flint 2. Flint is currently £84 whilst Flint 2 is £113.
I don't but from what I've read the WiFi issues are mainly to do with the 2.4GHz band and if you update to the official OpenWrt I believe this solves a lot of issues.
The Flint 2 has a 2.5Gb WAN and LAN port and also has faster Wireguard speed for the small price difference the Flint 2 is definitely the better buy.
The Flint 2 is also AX so faster WiFi speeds.
  • Like
Reactions: IC3
Bought it, paid £108. I'm thinking about getting another one for my parents, their Mesh setup isn't great...
Got the flint2 myself - Never had any issues with it, running 2Gbps symmetrical. Can pull 1500Mbps+ through WiFi to my Macbook and solid 2Gbps through ethernet.
Also has some nice built in features, Wireguard etc.
Bought 2nd one, can't go wrong for £108 I think... One of my elderly reletives recently got news that fibre is available at their apartment, so thinking about purchasing 3rd Flint 2, I think it might be a bit of an overkill tho... :p
