- 26 Aug 2010
- West Yorkshire
The VM superhub is downstairs, and i have one 50m cable running through the walls of the house behind the scenes into my room, the problem is that there is no wireless signal in my room, and a number of extra wired ports would be useful for laptops and other stuff.
The first thing i looked into was a wireless range extender, however that uses up the only cable that goes into the room, leaving nothing for the PC (wireless is not an option at 12.5MB/s DL speed)
Since the house wiring is pretty old, it is also not a good idea to gamble with speeds from powerline as i have a decent cable.
i have looked at this : http://www.overclockers.co.uk/showproduct.php?prodid=NW-204-NG&groupid=46&catid=1837&subcat=
which seems to be perfect for what i want, but the price is a little high. (budget is around £30) and some reviews weren't that cracking
the other option i saw was using another router to do the same task, but i've heard that some routers don't support being used this way.
http://www.overclockers.co.uk/showproduct.php?prodid=NW-063-AS&groupid=46&catid=1596&subcat=
this one is a nice price, but the website says "*This product does not support universal repeater mode." which seems to be what i want.
anyone got any recommendations, or can i indeed use this router for that purpose?
