WHICH RX480
Any idea which is quietest/coolest?
Guru3d reviewed the MSI one (8GB but I don't think it will make a difference) and said that it was very quiet indeed and also no trace of coil whine. Techpowerup reviewed the Sapphire one and said that it got noticeably noisier under load with the fans maxing out, but also said that would probably be fixed with a driver update. Probably both fine, but I went with the MSI one over the Sapphire one for this reason.
Just to let you know, the MSI ones are low on stock. New stock is said to arrive within the next 2 weeks, I know since I've ordered one myself.
The MSI is the one I want also but the price is all over the place. It was £270 this morning (still a little high I feel given the others are £250), but now its jumped back up to £300 which is way too high.
Why specifically seek out a very expensive custom card that is much more expensive than the standard? Do you think people here don't know you're doing it?
The £300 MSI card is specifically mentioned in this thread already here:
In fact you even recommend the MSI yourself. Then get in a flap when he compares the price of that card to a 980TI. Stop trying to create drama where there isn't any.
Fair enough. I just clicked the New Posts link and lost track of the context. Sorry.
Sapphire Nitro, MSI Gaming, Powercolor Devil and XFX GTR are all really good, toss a coin. :)
What about the gigabyte g1 or the HIS?
The gigabyte g1 hasn't got the clock specs listed still on the site. Can you confirm what these are now you have stock?
The gigabyte seems reasonably priced. How does it compare to the MSI for cooling and quietness please?
Well at least I got mine for under £210 for a 4GB one. Closer to £220 and I don't feel it's worth it. Not a factor of being able to afford it (since I've got spare £££), but more a factor of what I think it's worth. 4GB 480s are barely worth over £200 IMO.
I was always recommending the 4GB one... over £230 for even an 8GB RX480 isn't worth considering IMO. Ask yourself this... will you really be using more than 4GB on an RX480? And is 4 more GB worth like a £80 price increase? If you really want 8GB, then go RX470. It's barely an RX 480 itself, which means a significant bargain. Unless those are now well above £210.
Also the MSI 980ti's are sold out. I know because I bought one too (with the 480)... though I'm kinda regretting it since a new screen is more important. Without it, I literally won't see any difference upgrading to a 980ti except better 1080p performance in Arma 3 (boy that game is not great optimised).
Overall I'd recommend a 980ti if going for something over £250. 1060s make my blood boil and so do 1070s. Plus an OCed 980ti pulls ahead and rumours of Nvidia gimping Maxwell are nonsense. Or I'd already be feeling the effects on my 970. There have been many folks chugging along on older Nvidia cards (even the 200 series) on these forums, though recently many of them have upgraded.
Under £250 is where things get difficult, a 4GB RX 480 or an 8GB 470, though once again, the extra 4GB won't help all too much at resoutions like 1080p.
Edit:
The £199 Sapphire 4GB RX480s are perfectly priced as far as i'm concerned. You get a decent budget card for that can play most things at max right now (at 1080p) and will last a few years.
+1
Someone knows exactly what I'm on about. (next post)
