Which Ryzen for Gaming?
24 Apr 2010
NW
Which of the following would you suggest?
  1. R5 1600
  2. R7 1700
I'd expect I'd still be using this CPU in about 4/5 years. I would overclock it. It would pretty much just be used for gaming. Do you think the additional cores in the R7 are worth having for gaming in the next few years? Am I right in thinking that the additional cores of the R7 are of no use to gaming at the moment?
Honestly I would go with the r5 1600 and put the extra money towards a better GPU or faster memory. Very few games use more than 8 threads, and while things will hopefully improve, by the time they do there will likely be other reasons to upgrade, so 8 core unlikely to have a substantially longer lifespan than the 6 core.
Thanks. The 1600 is what I was leaning towards.
I have just watched these videos and agree with his thoughts. This guy gives his honest opinions and he does say that the 1600 is the best deal right now in the gta video.
bought a 1700 sent it back and will be picking up a 1600 next month when amd send out the memory update, putting the extra 100 to some faster ram..
I went 1700. I'm sure over the years those extra cores/threads will come in handy.
Depends on your money situation. Bang for buck the 1600, more longevity the 1700.
Depends if you plan on upgrading within 2-3 years or not. R5 1600 now followed by a 10c/20t 3rd generation Ryzen on the same motherboard in 2019 = win?
I'm pondering the same thing, I know 'bottleneck' is all game dependent, and I realise at 4k the GPU in most cases is the limiting factor, but would the 1600 hold back a 1080ti for 4k gaming?
Sorry to hijack the thread a little, but as where asking the same(ish) thing I thought it's would be better than starting a new thread
Another way to look at it tho, is current cost of 1600 + cost of 10c/20t ryzen vs just the cost of the 1700 middle ground.
In that sense, it's cheaper.
Yes it's a gamble based on how likely you think AMD are to improve IPC and clock speeds in their next two iterations. Personally I think it's pretty likely considering this is their first design based on a brand new architecture, plus it's their first 14 nm CPU and we already know that Intel can get to 5+ GHz when overclocked on the same node.
Jay z has a youtube video playing games at 1080p with 2 titans and seems to be doing pretty good
At £210 it's value is astonishing. :eek:
Go for it and put an extra £100 in to the GPU.
I don't think your regret it any time soon either way you go.
I went for the 1700 as I'd always envied people with 8 threaded CPU's and at £300 for my own I couldn't resist.
I suggest you do a lot of reading around at performance reviews and make a decision based on that.
If it's purely for gaming then the 1600 overclocked -- this platform is supposedly good for a few years to come so if you don't need the higher end thread count I'd save the cash for upgrades later on.
To give you an idea on 1080p playing BF1 on Ultra my rx480 is maxed out and my 1700 at stock speeds is barely pushed hitting a max of 51c using the stock cooler in game.
I went with the 1700 for more future proofing.
I'm in the same boat. 1600(x) or 1700. I see ocuk has 3000 bdie teamgroup? But if i go for 1600x and save some money do ocuk sell 3200 samsung bdie's?
