Which Samsung HELP!!
Need your guys opinions please!
Right I've been after a Samsung LCD for sometime and I'm confused on which to get! I'm going to be using it for mainly PC/Xbox 360. The two models I have
narrowed it down to are;
Samsung LE26R73BD 26" - I can get it for £589 delivered. (Discount Codes used - Usually £639.99)
Or
Samsung LE26R41B 26" - I can get for £549.99 delivered.
I'm not to sure on the difference between the above? Can someone help!?!
I'm coming from a 20" widescreen Philips 200W6CS. But I'll be going from DVI to using VGA, will the Samsungs look worse for PC stuff etc? And I'll be using the 360 with component now instead of VGA.
I’m Going to be ordering tomorrow. Need some help please!!
(And Yes I will post the discount codes from the place once I've placed my order. )
Or
