Which Sandy Bridge Cooler?
24 Apr 2006
SE England
Really not sure what cooler to choose for my 2500K Sandy Bridge purchase.
I have a Cooler Master Elite 355 case. The case isn't massive but a Scythe Ninja fits inside it with a couple of centimetres to spare.
Not wanting to spend a fortune on one but want a decent one.
Thanks for any help.
It is but I am not sure of the version I have.
I bought it about 4 years ago.. it is sitting ontop of a 755 E6300 Conroe.
Will it fit a socket 1155?
Thanks for the help Purgatory
It has a large fan looks to be over 120mm.
Shame, looks like I will have to purchase a new cooler then.
Any suggestions on what one to choose?
i just bought this..
http://www.overclockers.co.uk/showproduct.php?prodid=HS-031-TT&groupid=701&catid=57&subcat=
best air cooler for the money u can buy. keeps my [email protected] ht on prime @ 60c
Titan Fenrir Evo CPU Cooler
I went for this one having read several reviews on the web.
that ebing said most fo the ones mentioned above came out well
I just finished setting up my SB rig with a Venomous X Black (Thermalright) with 2x Xigmatek XLF fans.
PIC
The fans are all Xigmatek XLF 120mm. Great cooler without being ridiculous size/weight.
P.s I have no good camera!
P.p.s Ignore cables as I'm still testing :)
Depends if you want maximum overclock room or not and budget.
Titan Fenrir
Akasa venom
Frio
would all be good budget choices, the best cooler for around £40 is the cogage arrow but it's big.
