Which Sata3 port to use
3 Sep 2008
I am getting an Asus P8P67 motherboard and will be using a
WD 640GB 3.5" SATA-III 6Gb/s Caviar Black Hard Drive - 7200rpm 64MB Cache as my boot drive, Im just wondering which Sata3 port to plug it into?
The intel ports (grey) or the marvell ports (navy blue)
Thanks in advance :)
here on the actual mobo page
- Potential Sandybridge issue:
- In some cases, motherboards featuring the 6 Series Chipset (P67 & H67) that have Sata devices connected to ports 2-5 could potentially degrade over time.
- Motherboards with devices connected to Ports 0 & 1 remain unaffected or using the 6Gb/s ports.
- Please note if your board is affected by the above issues, your statutory rights remain to RMA the board.
- Tests have found that under 5% of boards are affected.
- PLEASE NOTE THERE IS NO POTENTIAL ISSUE TO SANDYBRIDGE PROCESSORS
