Which screen for PC and Xbox?
8 Nov 2005
Quick and easy question for you clever types. A colleague of mine wants to buy a screen that he can use for both his PC and his Xbox (the original, not 360). It needs to be a TFT, although I think that's probably stating the obvious.
What are the options, bearing in might he's a tight-fisted swine and would only stretch to a couple of hundred quid.
i think you would. If you wanted a dual input screen, the Hyundai L90D+ might be a good option and uses the same panel as the 913N anyway
