- 18 May 2010
Hi,
This is driving me nuts and I'm sure its simple and I'm over thinking it but was wondering what everyone else does?
On my previous system I matched all my case fans to CPU, CPU ramps up and so do case fans which was perfect.
On this system my CPU tends to spike the temp whilst doing basic tasks such as browsing the internet, this is driving me nuts because the case fans are ramping up and down all the time, not much I can do about the CPU as its a part of XFR so I tried to set a manual fan curve for the case fans but this has no effect what so ever, case fans just sit at minimum RPM and dont ramp up with the CPU temp, probably a BIOS issue that will be fixed eventually, switch it back to preset manual or silent and they match the CPU again
So I'm wondering, if I match the case fans to the System Temp (Motherboard temp sensor) the case fans dont ramp up under basic tasks which is great, but this sensor always seems to sit around 30C so how are the fans supposed to ramp up if the temp doesnt increase by much if at all?
And what is weird is the plot for all the sensors is the same, eg -
I set Case fan to CPU and the chart makes sense.
I set Case fan to System Temp and the chart remains the same as the CPU and makes no sense.
Its funny how something so simple is so time consuming and frustrating!
Cheers
Cheers
