I just got sleeping dogs, initially I put everything on maximum and FPS dipped in the high 30's sometimes.
If I put all the setting to high and a couple on medium I get a pretty solid 50-60FPS. I'm in the process of installing the high-res texture pack now as I read it didn't really impact performance.
My spec is:
i3 3220
7850 2GB
8GB DDR3
If you have the same spec as me could you please give me a run down as to how your settings are?
Thanks
My spec is:
i3 3220
7850 2GB
8GB DDR3
Thanks
that AA that kills framerate isnt really worth it without a 3GB+ AMD card.
