which shuttle
27 Mar 2004
Telford
hi
well i am going to build a new pc soon as mine is a bit old now xp2500
so i am looking for a new shuttle
have been thinking of these
Shuttle XPC SN27P2
http://www.overclockers.co.uk/showproduct.php?prodid=FS-071-SH (AMD)
or
Shuttle XPC SD32G2
http://www.overclockers.co.uk/showproduct.php?prodid=FS-075-SH&groupid=43&catid=110&subcat= (intel)
or
Shuttle XPC SD32G5 Black Intel Core2Duo Barebone System (cannot lnk as they are competitors and ocuk do not stock this one :( )
what are the main differences between the last 2?
will they run a reasonably good graphics card? as they both have 250w power supply
will they support quad core?
any other comments welcome
thanks
the only difference between the last 2 are the chassis style/look, aside from that they are the same as far as i know
they'll run pretty much any g-card you can throw at them also
not sure if they support quads or not, may be best to check shuttles website and check through the bios revision notes incase it was added as a bios update
