Which SLI connector do i need?
26 Dec 2009
North
Anyone know what type of SLI connector i need. Aqua computer blocks.
Got a variable SLI connector thing but its to big! The tube inside it spreads the cards too far appart.
1st PCI-E Slot - Graphics card
2nd PCI Slot - Empty
3rd PCI-E Slot - Graphics card
Metal tube is supposed to go inbetween the two fittings below, but its way too big.
I'd say two slot connector.
Afaik the connectors are measured of against the PCI bracket spacings, so if you have one spare PCI bracket between the cards then its a two slot - I think this is correct, I'm sure someone will correct me if I'm wrong :)
Edit: Fairly sure AC make some bridge type blocks similar to the EK ones...
No the brackets are touching, they are the normal dual slot brackets. The 2nd PCI slot is blocked by the bracket or would be blocked by a normal 2 slot air cooled card.
The bridge block connectors are expensive! just looking for a cheap fix.
