Which SNMP graphed monitoring suite?
We use Solarwinds which is good and very customisable, but quite time consuming to set up properly and probably too expensive for a small deployment.
We generally use Solarwinds to monitor Firewalls, Routers, Switches, Load Balancers, Servers and other kit (few different instances), and we use PRTG to monitor website avaibility for customers, and things like SSL certificates.
If you can get netflow configured also its good.
I setup LibreNMS from scratch and can recommend it, Nagios is another, but specific monitoring options might help dictate the software.
