Hey Guys,
Looking at getting the following system:
Processor - AMD Athlon 64 X2 Dual Core 5000+ 2.60GHz (Socket AM2):
Motherboard - Asus M2N-SLi Deluxe (Socket AM2) PCI-Express DDR2 Motherboard:
RAM - GeIL 1GB (2x512MB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX21GB6400UDC)
Hard Drive - Maxtor DiamondMax Plus 10 NCQ 200GB 6V200E0 SATA-II 8MB Cache - OEM:
Case - Akasa AK-ZEN-01-WH Zen White Case - No PSU:
BFG GeForce 7900 GS OC 256MB GDDR3 HDTV/Dual DVI (PCI-Express)
Optical Drive - Pioneer DVR-111D 16x16 DVD±RW Dual Layer ReWriter - (Beige) OEM
Can you check it over and also can you recommend me a power supply to go with it, preferably one that will handle another graphics card some time in the future.
Thanks
Luke
Thanks
Luke
