Which sound bar for around £200?
20 Dec 2007
Nottingham
I'm eyeing up the Yamaha YAS203.
Is there anything else i should be considering?
It'll mainly be used for movies, but sometimes music playback, so i'd like to have bluetooth connection.
Room size will be around 5.5m x 4.0m
Currently got a Panasonic Plasma from about 4 years ago, but will be upgrading this in the next year or so to something a little bigger hopefully. So I'm not looking to match the brand with the tv or anything like that.
I ended up ordering an XT3, it was a little over budget, but ordering via Amazon.fr got me it for a little over £240 including delivery
Thanks for the suggestions, I'm hoping it's as good as the reviews suggest.
Hi Darryl. I too am after one of these for the parents, is it just a simple case of logging in with your normal details and ordering? Would this come with a euro plug? It would seem a no-brainer to order from them as that is over £100 cheaper than anywhere ele!
W.
I've just bought the yamaha YAS105 and can't fault it. Sound quality is great, has a decent amount of bass from it but you can also add a sub to it.
W.
Ordering process is the same, you'll be asked what currency your card is in, then what currency you want to pay in. You'll have to work out if it's cheaper to pay in Euros using the exchange rate and charges your card provider offers, or the amount Amazon charge for paying in pounds.
When I ordered my Nexus 6 it came with a Euro plug, so I'd expect this to be the same. I'll either use a converter, or order a new power lead for it.
