Which Sound card for 7.1 Creative Inspire speakers and DJ mix recording
1 Dec 2004
S.Wales
I have just bought a new set of Creative Inspire T6100 7.1 speakers, and i am a DJ so regulaly record mixes using Sony Soundforge, I want to get the best quality sound when recording mixes. Which soundcard would you reccomend? I am currently using onboard sound which is OK for now.
I am on a buget of around £20-£30
Thanks
If you do not have quality speakers then your mixes won't be a "reference point" so others with different speakers will find it EQ'd too much, because your own speakers have a borked frequency response.
So if you could recommend a decent pair of speakers I can use for both mixing with and for PC use then I would greatly appriciate it, bearing in mind I dont want it to cost me an arm and a leg.
If this isnt possible then I will just have to get the above creative speakers and do what I was originally planning to do and get seperate Monitors for my decks.
