- 9 Nov 2004
- West Midlands
Ok guys I think it is time to upgrade my sound card. I'm currently using a Soundblaster Live 5.1 card and want something with the newer technologies onboard EAX5 etc...
I want to be able to use it with a 5.1 speaker setup and 5.1 headphones so 7.1 support isn't needed at the moment but might be a future upgrade at some point. So far I've been looking at the Soundblaster X-Fi range but don't know which is the best bang for buck so to speak.
The card is going to be maily used for gaming, FPS, Racing Sims, some movie viewing and also a little vocal recording as well so low latency ASIO support is essential, out of the X-Fi range or any other cards, which would you guys recommend, I'm set to spend up to about £120 on a card maybe more thanks.
Stu
Stu
