Hi
Right seeing how i want to totally upgrade my sound setup on my pc i was also thinking on the soundcard also. I have mentioned in the past that i am currently using a very old soundblaster 5.1 and mainly will be gaming above most things ie music, movies etc.
I have ordered a Zalman's surround sound headphones (and i know) some have mentioned to get a proper set to be far superior but i got a limited budget and the set i ordered are meant to be pretty good for gaming nevertheless.
The soundcards that i got my eye on is either the creative X-FI xtreme gamer or xtreme music. Searched before and read that there isn't really a difference between the 2 and that the music would have better components as it basically the same card. However i was looking around and xtreme gamer is classed as a 7.1 surround card whereas music is only 5.1. The other thing is that the music has a manufacturing warranty of 2 years but says nothing for gamer. Am i right in thinking that both cards should be 2 years standard.??
Any input on what u would choose would be appreciated.
Cheers
Kyo
P.s i will be running xp so that 4gb ram issue on Vista shouldn't be a issue hopefully.
Cheers
Kyo
so i suppose i can strech my budget and get a decent pair instead. Which i know many of you will agree after reading so many threads that the general consensus is that surround sound headphones are vastly inferior to a decent set of headphones.
