Which Soundcard
26 Aug 2004
Derby-UK
i've been too lazy to buy a sound card for the last 4 years and have just used the onboard ones.
now i am in a position where i want to out a lot of old music that i have on master tapes onto the pc so i can play with it and then put it to disc. Currently i am using the Logitech Z5500 speakers but through ordinary leads. i have been told i need an optical cable but have nothing to connect one too at the moment.
as i am so far out of date with this side of PC's, could anybody recommend which is best to get for both sound quality and recording. i don't mind paying up to £150+/- if i have to but if you say one at £80 will do exactly the same with all the inputs i need ect then that's just as good for me.
one final thing, is there a lead that allows me to use standard amplifier phone plugs to sound card jacks? amplifiers have left and right out but do sound cards just have one port?
thanks for both replies. now i have to decide which one is really the best one for my purposes.
i am guessing that the asus one is just a card that plugs in and only has port connections from the back, whereas the creative one looks like it has a front panel that might be handy.
looking at them it seems they might both have phono inputs which would be really handy. the remote control isn't really required as my speakers are remote control and that's all i need for volume remotely. i just wonder weather you are paying that bit extra for the creative one because it has a remote.
does anybody else have any views on the two cards suggested? i am happy to buy either. do these cards have those optical outputs as well or isn't that a good idea?
___________________________________________________________________________________
i've just done a bit of searching for some more info, the Asus one appears to be 118DB over the Creative 116DB. 2DB is noticeable. also while looking for info on them i found this one by creative: -
Creative SoundBlaster X-Fi Elite Pro 7.1 Soundcard - PCI Card With I/O Console and Remote
it seems an improved version of the the one you have suggested (nearly £200 though it's got me itching now) but again, is only 116DB.
You can use a stereo jack to phono lead for a standard amp
A lot of xfi owners are ditching their cards and getting the asus xonar and auzentech prelude cards
thanks for the replies everybody.
do you know why they are ditching them now then?
are there many differences between he prelude and the asus?, i am leaning towards the asus one now.
thanks again C64.
the final question i would ask then, if you don't mind, given the choice (assuming you didn't already have one)
which of the two cards would you go for if you were choosing as i am? reading the reports i can see the Prelude seems to be showing a few driver probs,mine too would be for XP not Vista.
Reviewed by: MARTIN
solid piece of hardware that actually upmixes properly (unlike my new CL Elite Pro!). However, I wasted an entire weekend trying to install in a mid-range XP Pro based HTPC system due to faulty drivers. The problem was eventually solved with the 28 Dec 07 driver release, but its taken a few weeks to calm my rage and enjoy the finished product. Purchased specifically for its dual Coax/Optical I/O which provides unsurpassed connectivity and future proofs planned SS Amplifier upgrades.
I have subtracted one star purely due to the time wasted during installation, otherwise an excellent purchase and a real improvement over my top of the range CL soundcard fitted to my main gaming PC.
I have 2 xfi xtreme music given the choice I would get an xfi extreme music as I don't think the asus or any other card is worth double the cost.
i usually agree with that. when new processors are released there is always a price tag of at least double the one below it.
however, on this occasion, this isn't costing me anything up to £150 because it's sort of free money (easier not explaining it...legal though) so i don't mind at all spending that much. there must be a few advantages of those cards over the cheaper one, all be it that they may not be worth the double cost but that doesn't matter on this occasion.
The issue with Creative-based cards (and that includes the Prelude) is drivers. Fortunately you're on XP - Vista has caused no end of problems for Creative card owners.
My personal view - for a top notch (in the price range/segment) music card, get the Xonar (it's what I plan to do if/when I eventually decide to upgrade). For gaming, Creative still has a big lead despite the driver issues.
My last soundcard purchase was an SB Live! though, so take this advice with however many pinches of salt you feel are appropriate. :)
thanks for that as well, just a little unsure which you mean though?
you say go for the xonar but the creative is better for gaming?
i do like the looks of the prelude, i actually like the front panel idea but it looks like the Xonar would be the better option.
i hate all this asking..i'm just dying to click that "add to cart" button :D
it's a good job it didn't add it. i can't believe what an idiot i have been. my mobo is over 2 years old. it's the old Asus A8V Deluxe rev 2 board.
it doesn't have any pci-express slots :mad::mad::mad:
now what :(
xfi xtreme music or Asus Xonar D2 7.1 PCI Sound Card only the d2x is pci express you wont be disappointed with either
As far as I am aware all the xfi cards are no better than the xtreme music just that they come with front panels or external boxes which aren't really needed for my needs only card I'd swap out my xtreme music for would be the asus xonar d2 but I am quite sure I will not notice a difference in sound quality even though I do have reference headphones.
Yea prelude or xonar d2
or xtreme music if you're feeling stingy but still want great sound.
ahh so it's on again then
so there isn't much between the Asus Xonar D2 and the D2X but the D2 is PCi?
i'll have a look too because if the Prelude is a PCi and does come with a front panel, that would be handy for me on this occasion.
__________________________________________________________________________________________________
ok i've looked. the Prelude does come with a front panel but is it definitely PCi only because it doesn't state what it is on there?
- Creative X-Fi CA20K audio processor
- One AKM AK-5394 super high performance 192kHz 24-bit ADC for analog input
- Four AKM AK-4396 192kHz 24-bit advanced multi-bit DAC for analog output
- 64Mbytes of memory for audio processing
- High fidelity audio OP-Amps for analog input and output
- Front L/R output OP-Amp is replaceable by end-user
- Dual mode S/PDIF receiver and transmitter
- One 3.5mm MIC input connector in rear panel
- One 3.5mm line input connector in rear panel
- One 4-pin AUX connector on board
- Four 3.5mm 8 channel line output connectors in rear panel (FL/FR/C/SW/RL/RR/RSL/RSR)
- One S/PDIF combo input connector in rear panel for receiving either coaxial or optical digital
- One S/PDIF combo output connector in rear panel for transmitting either coaxial or optical digital
- 16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
- One 10-pin front panel connector on board for MIC input and headphone support
- One 40-pin digital extension header on board to support AD-Link and other digital functionality
- 24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate
- 24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog 7.1 speaker output
- 24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to stereo output
- ASIO 2.0 support at 16-bit/44.1kHz, 16-bit/48kHz, 24-bit/44.1kHz 24-bit/48kHz and 24-bit/96kHz with direct monitoring.
- Enhanced SoundFont support of up to 24-bit resolution
- 64MB of X-RAM
