Which Spray Paint do I need?
16 Dec 2009
Bolton
I didn't know where to put this thread so I banged it here in Case Central. Anyway I want to spray my crossfire bridges black instead of the horrible dirty orange colour. Does anyone have any Idea what the best Spray-paint is?
Etching primer & paint with plasticizer in it (used for plastic bumpers etc). This paint will not split when you flex the link.
You can also purchase vinyl film that is glued on one side (the carbon look is very nice). Have a search on the bay
Highly reccomend you don't try to paint. Use black electrical tape (or any other colour for that matter), or as Piggin says, use adhesive film although you'll have to buy a quite large sheet for a small job but does look good.
