Which steppings are better for A64 3700's ?
14 Nov 2002
I have seen these two available, which is the better one ?
ADA3700DAA5BN
ADA3700DKA5CF
Or do all 3700 O/C pretty well ?
No not all of them clock well. I had one that wouldnt go past 2.7ghz but then i got this one:
KABCE0542FPMW
which does 3.1ghz @ 1.54v on air (very quiet air cooled as well) although i dont use it any more as have a 170 @ 3ghz. Generally the newer ones seem good.
Mine is ADA3700DKA5CF & it's a pile of pants wont go over 2.54ghz.
Got it at 2.54ghz using 1.45 volts & cant increase cpu speed any higher not even if using 1.65v
I got a retail one from here about 2-3 weeks ago and thats sitting at 2.8 @1.55v prime stable. Boots into windows at 2.9 but not got it prime stable at that yet. Clocks are on air aswell and temps are 28/9 at idle and my max during prime 95 was 40'c.
ADA3700DAA5BN
ADA3700DKA5CF
The 2nd line is more important like KABCE0542FPMW or CCBWE0542VPMW as that is the stepping and production week.
