which system would you choose and why?
27 Oct 2012
hi guys, I am building a new system and I have 2 set ups, 1 of my own (first 1) and another which some1 was kind enough to recommend. I purely use my pc for gaming and nothing else. I have no idea what I am doing so I thought I would ask the pro's on here :p I am unsure if the system I put together would connect correctly let alone fit in the tower I selected. any advice would be great, or should i just choose the 1 some1 has recommended me. my budget is around 1200 currently so any advice etc would be appreciated.
also will the cooler I chose be suitable for the cpu? or would you recommend something else?
my build
My basket at Overclockers UK:
Total: £1,148.11 (includes shipping: £15.30)
some1 recommended this... hopefully this link will work ok.
https://www.overclockers.co.uk/ocuk...pc-configurator-fs-1aj-og.html#t=c7e?f4g0h(j7
the main reason I chose the cpu I did is because of this website. maybe I am a fool for listening to it?
thanks for any advice
http://cpu.userbenchmark.com/Compare/Intel-Core-i3-8350K-vs-AMD-Ryzen-7-1700X/3935vs3915
Hi,
The build posted below has a much faster GPU, similar CPU (faster in some scenarios, slower in others) more RAM and at a faster speed, and a better PSU. The disk drive is missing, but the included version of windows 10 comes on a USB key - so no need for a disk drive. The case is sound-dampened, has a PSU shroud and is easy to build in.
If you wanted an Intel build (i5-8600k/Z370/CPU cooler) you'd need to drop down to 8GB RAM, swap to a GTX 1070, get a cheaper case and a cheaper PSU.
But, the Ryzen build offers more performance in my opinion. Also, the AM4 motherboard socket that Ryzen uses also has a great upgrade path until 2020. In February of next year AMD releases their next iteration of CPUs called 'Ryzen+'. This could be a great option if you find the Ryzen 1600 to be too slow.
Total: £1,264.57 (includes shipping: £14.70)
If you wanted to get closer to £1200 - get a cheaper case, PSU, motherboard (MSI B350 PC MATE)
I have i5 8400 and Ryzen 1600 and would pick the Intel for gaming .
I don't think in the above video it's overclocked .
Searching around you'll find i5 8400 was recommended for the budget gamer, as WHEN it was released it was only £20/$20 more then the i3 8350k.... Now it's a lot more pricer .
Prob would recommend that above build , few slight tweaks for GPU with longer warranty.
Ditching the 275gb SSD and 1 TB HDD for a single larger 500gb drive. Can always buy HDD later as prices won't increase compared to SSD. Installing windows Fall update take£ up 40GB , can delete older versions to free up some space though !
Total: £657.23 (includes shipping: £12.30)
Saving on case and card get moved to the SSD .
If not keep the to drives above and saved yourself £20
As for cooler
£25 aftermarket will run it 20c cooler.. but damn , 4ghz ... Got a lucky chip, wonder how many volts through that
