- 29 Jan 2008
Hello dudes was thinking about overclocking my cpu so started to run prime95 after some advice form another thread to see what kinda temps i'm getting, however all the temp programs i'm using are giving different results and i dont know which to believe.
Could someone tell me which is the most accurate out of Realtemp, Speedfan and coretemp.
And could you tell me if these temps are ok with my current set up :-
Q6600 at stock with Corsair H50 with 2x Apche fans cooling radiator push/pull
Here is a link to a screeny I just took whist using the prime95
http://img689.imageshack.us/img689/6927/cputemps.jpg
And if these temps are ok , would I be able to get my chip to 3.0ghz ish?
