Ok, so core temp shows idle at 55/56 degrees and full load at 76/77 or 81/82 degrees depending on what it's doing.
Easytune6 that was bundled with the mobo shows CPU @ 43/44 idle and 72/73 at full load, so which do I trust? I must admit the core temp figures have me worried a bit although the case is barely warm to the touch and neither is the air coming out of it.
It's an AMD E-350 Gigabyte board, the heatsink has it's own 40mm fan and the case fan is a Noctua 80mm running at it's lowest speed, to be honest the case fan makes no difference to temps, I just have it on for some air flow through the case.
