Hi, my old 15" CRT monitor is starting to break so i'm going to be getting a new monitor soon.
I only have around £180 to spend and have been looking at the following:
Acer AL1916W 19" Widescreen LCD Monitor - Black/Silver (MO-012-AC)
Neovo F-419 19" LCD Monitor - Black/Grey (MO-016-NV) -
Samsung SM-913N 19" LCD Monitor - Silver (MO-022-SA)
I will be using it to watch dvds and play games, I like the look of the widescreen because it will be good for dvds but is this good for games?
The neovo monitor has a dvi port, does this make the quality much better?
Which one would you recommend.
Thanks
Thanks
You wont really lose anythig vertically over a 15inch CRT but it will be much wider res and actual size
