Which thermal compound?
Personally I've always used Mx-4 over silver, non conductive, spreads easier, easier to clean off, better temperatures on my rig.
Can't put it better than that!
I still use MX-4 and sometimes AS5 - I've rarely seen much if any difference between the two tbh (MX-4 seems to give slightly better short term results but tend to even out long term), I'm not a fan of spreading by hand either - I've consistantly seen the best results from drawing a line of paste over the cores.
EDIT: The only exception to that is the Gelid extreme which has the viscosity to spread properly.
Liquid ultra here, you do have to be careful applying it though. But its much better than conventional pastes.
