Which of these sets would be best for a AM3 build?
1) http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS
2) http://www.overclockers.co.uk/showproduct.php?prodid=MY-201-OC
3) http://www.overclockers.co.uk/showproduct.php?prodid=MY-191-OC
I've been told timings wont make a massive amount of difference, but 2nd lot are on offer and have 6-8-6-24 timings, does this mean they are better than the more exspensive 7-7-7-24 set?
Or would you guys recommend the corsairs instead? (9-9-9-24)
If the reapers are the way to go, will they fit in an antec 300?
Ta!
Ta!
