which to overclock.
Permabanned
27 Apr 2009
i have ram at 1077 Mhz @ 5-5-5-15.
should i either keep that speed or would i benefit better if i decrease clock rate and decrease the timing.
my uses is gaming. Mainly crysis which uses 2 GB.
on RAM website it says 2.1-2.2 volts. what happens if i go over this, will it damage my ram or just void my warranty?
you would not see any difference at all over clocking your ram
i went from 6400 to 8500 with nothing changing at all, including crysis game-play, you will just run the risk of damaging the ram
Have a play with each and see what's stable, then ask for suggestions as to which to use / benchmark it.
Last ocz I tested would do 1150 at 5-5-5-18 but only 850ish at 4-4-4-12. Widely varies with your particular ram.
Neither is going to make much difference, I tend to run 1:1 with fsb at whatever timings it can manage
