Hey Gents,
Just had Sky internet installed, i switched from virgin. I know a bit of a silly move going from cable to adsl, but i had enough of Virgin and the way they treated me after being customer since 2003, but that's story for some other time.
I want my main PC to be wire connected with modem, my daughters laptop and my PS3 will go wireless.
I need about 16 meters of cable to get to the room where my PC is.
I have 2 options, go with RJ11 extension cable and drive signal cable to my room and connect modem there.
Second is leaving modem where it is now and using network cable http://www.overclockers.co.uk/showproduct.php?prodid=CB-038-OK&groupid=701&catid=48&subcat=1069
to plug into my lan port on pc. It is shame that there is no 20 meter cable, 30 is almost double the length i need, can too long cable have negative effects on data transfer?
I dont know much about ADSl as such but so far i have concluded that it is best to leave modem as close to the main socket as possible, so i am thinking best to go with network cable?
Also sagem wireless modem/router sky provided me with is not up to the job, you need to be fairly close to it to get good signal, i was thinking replacing it with this http://www.overclockers.co.uk/showproduct.php?prodid=NW-081-BE I have cable version of this (well they look the same) and its been really good, is this good one to go for?
Cheers
Ved
Cheers
Ved
i am not so far from you, Dundee.
