- 11 Sep 2014
- Suffolk, England
Okay so I'm in the planning stages of my first custom GPU & RAM loop and was wondering which fittings I will require.
Details and picture of the loop I have in mind:
Tubing: 10mm ID/13mm OD clear hard acrylic
I want to use the least amount of fittings as possible, so preferably just ones to connect the tubes to the components & any bends will be created with the tube itself.
Bearing in mind, I'd like all angles of the tubing to be the same for symmetry sake.
