Hey peeps,
Just got home to find I have flat tyre on the front of the Yaris. I've got the nasty spacesaver on there for now but need to get a new tyre as soon as possible.
I may as well replace both front tyres seeing as the treads getting low anyway, so while I'm at it so thought I wanted to see if you lot had any recommendations. It's fitted with Dunlop SP9000s at the mo in 195/50/15, and they've been quite good tyres actually.
Used to have Toyo T1-S on the 106 and found them grippy in the dry and mediocre in the wet..are the T1-Rs any better?
I have a budget of £100 for the two tyres and fitting. What do you recommend? Thanks!
Andy
Andy
