which USB for a mp3 player...
25 Jun 2004
in the clouds
I need a new USB cable but I dont want to order the wrong one. Is a standard USB cable the type that will fit a mp3 player (small oblong end) or is a standard USB cable like the ones with a larger square end that fits printers? :confused:
well.... it depends on what Mp3 player you have O_o
chances are it'll be the small one
but some players have custom cables.
Archos AV420, I didnt realise that there where two versions of the small one...whats it called? I need to know this before ordering.
USB Cable (Mini B / A) is whats listed on the Archos website, but im after getting one off ebay with a blue led inside, if I can find one...
