Which USB Wireless Adapter for use with Mac Mini?
Most of them don't work properly, and the drivers are useless if they do work at all... they'll randomly break with OS upgrades etc. :(
A wireless Ethernet bridge would be a much better idea.
You can get them for about £40 which is a similar price to a decent USB adapter really, maybe cheaper depending where you buy it. I's basically a Wireless adapter that's connected to your computer via ethernet rather than USB which saves the need for any drivers. They are sometimes advertised as "wireless gaming adapters" because games consoles lack USB and instead use their ethernet port.
ah cool thatll be fine and save me using a usb port too! any recommendations which one to get?
Ghost in the Shell said:
yes i have a card here but i believe you need an antenna as well. i dont fancy opening it either so im looking at other options
I installed one in my parents Mini, it was VERY easy, a lot simpler than i thought it would be :) Also, OS X picked it up straight away when turned on!
There are full instuctions online for the installation, and they cover every little step to install it.
mate will you mail me (email in trust) with some more info and the correct parts i need etc..
thanks
thanks
I'll post here so everyone can see :)
You need an airport upgrade kit:
New one.
I think that's the old one.
This isn't the guide i used, but it shows how to do it anyway:
http://www.ifixit.com/Guide/82.11.0.html
and this is the one i used (Apple service manual):
http://www.repairyourmac.com/mac_mini_sm.pdf
It depends what revision Mac mini it is... only if it's a 1.33 or 1.5GHz model (the unannounced upgraded models) will that fit.
its the 1.42 G4 PowerPC with superdrive
i have just bought from ebay an airport extreme card but i can see thts not enough. can i buy the other bits seperately or do i just sell what i have and get a new kit as pictured.
the actual item i have here is :
Airport Extreme Card
Part Number: M8881Z/A (model A1027)
Looking at the picture in my post above, it looks like the Airport Extreme Card is one for more than just the Mini. For the Mini is appears that you need the blue board that your card slots into.
