Which vertical mount for Lian Li O-11 Dynamic white?
Caporegime
17 Jul 2010
Apparently the official one can’t be used with fans in the bottom which seems like a no go to me due to restricted airflow so is anyone using a vertical mount which has room for bottom fans? if so, which one is it? This will be with a Gigabyte 3080 Vision.
I have the phanteks in the 011 with 3 fans at the bottom. Tons of room
This is the one I ended up picking up and it's great. No noticeable sag and plenty of space at the bottom.
Just need three more white Uni fans and to swap over a SATA SSD and a 2TB mechanical and we'll be good to go!
Very nice build!
I'm in the process of gathering parts for a new build and wanted to know what you think of the Galahad AIO, efficiency and noise wise? I was going to go with a 360 Corsair capellix AIO but reports of a noisy pump has put me off so Im looking for alternatives (which must be white to match the build).
Very nice build!
At the moment I don't have a clue how noisy or quiet it is, my Windows USB stick has gone missing so it doesn't have windows on it yet. I also need to make a few changes to my desk area. My current PC sits under my desk to me left but it would be criminal to put this there so i need to clear some space top the right of my desk to put it there. I was thinking about going for a white or light blue for the RGB, but I've always been a sucker for an 'electric' blue.
Oh I did a wee build log post too! Nothing fancy, just a O-11 Dynamic white build trying to make it as 'clean' as possible. | Overclockers UK Forums
Oh no, well I hope you manage to get your hands on the missing stick soon!
When you do finally manage to sort it I would still like to hear your opinion on the Galahad. My Motherboard won't be with me until the beginning of March at the earliest so I have plenty of time to make a decision on the AIO.
Also thanks for your build link, I'll check it out :)
