- 29 Dec 2009
You're mixing up the old and new VMware names for things. ESXi doesn't really exist any more, it is now the vSphere Hypervisor. The Windows client for managing things is called the vSphere Client.
When you have a bunch of hosts then a vCenter Server instance manages them as a group, and this itself is managed with either the vSphere Client or more recently through the vSphere Web Client.
, had no real need to shift from 5.1I've been trying out XenServer and tried to run a few hotfix updates which resulted in the OS having a kernel panic when it tries to boot unless I run in "fallback" mode..
I've now installed VMWare ESXi 5.5 under the impression that it was free, however, upon logging into the vSphere Client, it says "Evaluation 60 days left"..
Which virtual OS's i.e. Xen, are actually free then?
See I would have known this if I was using 5.5
I only use hypervisors at home now, as my job entails purely core network and network security, where as my last job was a mixture of Network engineer, Server and DC engineer so was using VM Products all the time.
I may have a play around with 5.5 at some stage, but would only be a trial, had no real need to shift from 5.1
5.0, 5.1 and 5.5 keys are interchangeable![]()
This article provides steps to add, assign, remove, unassigned, and change the licenses of ESXi 5.x, vSOM 5.5 (vSphere with Operation Management Suite), vCloud Suite 5.x and vCenter Server 5.x.
Notes:
The vSphere 5.5 does not need new license keys. The existing 5.0/ 5.1 licenses will work and enable all the features of the software once upgraded
To determine if you need a new license key for the latest version of VMware product you own, see License key requirements for new version of VMware products (2059926)
All ESXi 5.x and vCenter Server 5.x keys work with ESXi 5.1/5.5 and vCenter Server 5.1/5.5. To update your software from 5.0 to 5.1/ 5.5, see Installing or upgrading to ESXi 5.1 best practices (2032756) and Upgrading to vCenter Server 5.1 best practices (2021193). For information on upgrading license keys, see Upgrading license keys in My VMware (2006974)
The ESXi 5.1/5.5 features are automatically enabled after you upgrade from ESXi 5.0 to 5.1/5.5. This does not need a new license key
You can view and manage your license keys in My VMware. For information on viewing your license keys, and for links to information on managing your license keys, see Viewing license keys in My VMware (2006831)
) and just installed 5.5 on another stick
