which water cooler
20 Sep 2007
I have decided to go with a 8800GTX in my system (following advice on previous threads). My question is what water cooler to buy as I dont want to pay nearly £70 for a GTX with one installed already.
Do you already have a watercooling set up? If not you will have to spend a lot more than £70. If you already have watercooling you can get an EK 8800 GTX block for around £54 inc vat.
The EK block is very good as pastymuncher said but you'll also need a rad, pump, res (fillport could be used) etc.
If you were looking at getting one of the all in one things like the Leadtek Leviathan I wouldn't bother, the Thermalright HR-03 will do fine and it's only £30.
