Which Watercooling
24 Mar 2006
Hey, I’ve decided to go for water cooling but I am unsure of what to buy as I am new to it.
Id want to cool the CPU, chipset and two 7800GTs with a view of upgrading to a newer graphics card around March time.
I have seen the Swiftech H20-220 Apex Ultra+ here. But notice that it comes with only one VGA block. Would this kit be suitable for my setup above with two VGA blocks?
Or would it be better for me to buy the parts separately? Would it be cheaper? I would have to do some research into the best parts, but as I am a newcomer to water cooling this might not be a wise idea.
I have looked at several past posts and they haven’t helped me greatly. Hopefully I can be pointed in the right direction.
Thanks in advance... :)
Go for the regular apex kit then once you upgrade your card(s) you can decide which gpu cooler(s) to add.
