Which waterpump
17 Mar 2004
Walsall
Decided to change the waterpump with my timing belt and have the following options. Genuine Honda waterpump too expensive.
Firstline £29
Circoli £24
GMB £36
Blueprint £42
Will any of the above be suitable or would one be more prefrable than the other? Was just thinking of getting the Circoli one.
The car is a 2000 1.8 Accord Vtec SE Exec (F18B2)
So you're going the extra mile by taking the precaution of changing the water pump with your timing belt, GOOD
Then skimping on £18 to do it cheaply, BAD
Go hit some owners clubs for recommendations!
How much is the genuine one then? The only 'brand' I've heard of there is blueprint, and my experience of their stuff tells me it isn't the best.
I would go for genuine on something like this. It is a critical part and if you want the quality and reliability that a Honda should have then you need genuine.
Blueprint, I always use Blueprint parts on my previous Honda's, OEM quality fraction of the price. Only problem i've ever had is a pre warped brake disc for some strange reason! In fact my local Honda supplies Blueprint parts to keep the costs of servicing down if you request it
