Which way around does my fan go ?? Quick Reply Please :)
If you have a look on the edge of the fan youll find 2 arrows that display rotation and airflow direction.
In the pic above youll see how the fan is mounted, on one side of the fan theres a small bracket on the frame that holds the centre motor hub in place, this side should be facing the rear of the case.
so my fan is to be mounted from one side (ie 2x screws rather than 4 across each corner) ?
if so i thought that was abit puzzeling since there isnt a spot on the case for each corner of the fan to be screwed into the frame. its just down one side.
Youll need to remove the front panel and insert the fans into the 2 bays in this pic.
Quite a neat idea how they fold out.
I think your supposed to place them behind the open out door, see below.
Note the 2 thumb screws on each bay, removing heese opens each bay to allow the fan to be installed.
