4 May 2006 at 15:54 #1 Dilzem Dilzem Associate Joined 18 Sep 2005 Posts 81 Location South East London just got a zalman ZM-F1 want to blow air out the back of the case do i put the fan on with the label facing me or the oposite way?
4 May 2006 at 15:56 #2 welshtom welshtom Permabanned Joined 17 Aug 2004 Posts 3,462 Location Pencoed the label faces which ever way you want the air to go
4 May 2006 at 15:59 #3 Dilzem Dilzem Associate OP Joined 18 Sep 2005 Posts 81 Location South East London so if i have the fan on the back with the label not facing me that is the right way if i want to blow air out the back
4 May 2006 at 16:00 #4 welshtom welshtom Permabanned Joined 17 Aug 2004 Posts 3,462 Location Pencoed if you look at the label straight on, the air will be blowing in your face.
4 May 2006 at 16:01 #5 vanandjuanunited vanandjuanunited Soldato Joined 20 Oct 2005 Posts 5,946 Depends where you are standing. Put the label against the case if you want it to extract.
4 May 2006 at 16:02 #6 Dilzem Dilzem Associate OP Joined 18 Sep 2005 Posts 81 Location South East London ok guys cheers i was the right way after all
