Which way round?
28 Dec 2003
Finally got all my bits together so will be building the new box at the weekend.
One question I do have however is which way round the XP-120 sink should be mounted. Once mounted on the board in the tower case, should the heatpipes be at the top or the bottom or doesn't it matter?
Shouldn't matter mate as on the dfi boards some have the heatsink one way round so they can access the ram and then some have it so the ram slots are blocked, should work the same either way round.
