- 17 Jan 2007
- London
Currently got the spec in my sig, but looking to upgrade the graphics after the BF3 beta (Im using 1920x1200, was getting minimum 44FPS/average 55ish with mostly high/Ultra settings.)
I know it was a beta and the final product is likely to be optimised, but Im not sure how much mileage they'll squeeze out of optimisation to be honest....
Given Im still on 775, I think my options are:
- Sell the 6970 and get a 6990 (I dont have CF on my mobo) and keep the current setup (perhaps upgrade the PSU also??)
- Sell the majority of the kit apart from the 6970, get a 2500k/Z68/16GB ram/new PSU/additional 6970 to crossfire
I mainly use it for gaming, but I need to setup some VM's for some labs Im about to do and 8GB isnt cutting it...
Which would you go for, am I likely to notice a massive gain in performance by switching to i5?
I did a rough estimate of how much either of these will cost, option 1 will be about £700ish, option 2 would be pushing £1k....
