- 19 Jul 2007
- notts , uk
not sure which way to go gfx card wise , i had a gecube 3870 special oc model with gddr3 . when the 4870 first came out i save and purchased a sapphire 4870 512 , but at 1680x1050 in nearly all games i got some stutter . in the end i sent it back after 8 month of this and got it replaced , but while waiting for the card to be returned i got a x3 phenom II 720 and the biostar ta790gx 128m mobo .
when i got it back i did a fresh install of vista 32bit with 4gb of 1066 mhz ram etc , but the stutter returned so i put my 3870 back in and purchased a second hand matching card . running crossfire i was surprised that the stutter had gone but the fps was down a little (sorry for the babble
now i have been offered a brand new his 3870x2 very cheap , should i get it or spend on a 1gb gfx card ? . my max £££ limit is £110 (at a push £120) , is it worth getting a 1 gb 4870 or just tri-fire the 3870 till the next gen cards come out ?
but if i tri-fire i need a new psu which has enough 6pin pci-e + 1x 8pin power connectors , the psu i am looking at is below and it will cost the same (psu + 3870x2) as the £110 for a 1gb 4870 . is a 6pin to 8pin adapter available ?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-PP&groupid=701&catid=123&subcat=1104
)now i have been offered a brand new his 3870x2 very cheap , should i get it or spend on a 1gb gfx card ? . my max £££ limit is £110 (at a push £120) , is it worth getting a 1 gb 4870 or just tri-fire the 3870 till the next gen cards come out ?
