Hi all,
So I need a PC, the driving excuse/reason being to allow virtualisation to get myself through various industry certs, the residual benefit being a return to PC gaming.
I spent from '97 through to '09 building my own PCs (and everyone else's!), gaming, etc. I've had most consoles over the years, but back in '09 I ended up switching to Macbooks of various guises for my own non-gaming computer uses, and sticking to consoles for gaming.
I did build myself an AMD FX8350 gaming rig a few years back when AMD released Piledriver CPUs, and started playing with it - but the better half ended up with it after their computer accidentally "drank" wine.
The only PC specs I really deal with these days is when it comes to spec'ing out servers for work, but with more and more apps, etc moving to the cloud, I deal more with resource names/qualifications than I do real hardware specs.
Soooo.... After that wall of text, I'm after a bit of advice from those of you that are still day-to-day drenched in hardware.
I gather that until AMD get their act together and release their Zen processors that they're lagging behind Intel again (booo... I prefer AMD, but not if they're not match-ready!).
So the realistic options are:
- Z170/Skylake.
- X99/Haswell-E.
- X99/Broadwell-E.
From a bit of research, the X99 chipset is going to outlive the Z170 chipset, and supports more threads/cores? Also from what I gather, Broadwell-E CPUs don't overclock as well as Haswell-E CPUs?
I've built three systems on OCUK, all to roughly the same cost:
1) Z170/Skylake - OCUK built (saves me a few hours, nothing major though):
My basket at Overclockers UK:
Total: £1,973.96
(includes shipping: £14.10)
2) Z170/Skylake (self-build, plus Asus Strix GTX 1080 OC version):
Total: £1,838.82
(includes shipping: £0.00)
3) X99/5820K (again with Asus Strix GTX 1080 OC version):
Total: £1,958.82
So from what I can see, option 3 would be best unless someone can correct me on that; the X99 chipset has more longevity, and the 5820K has better OC'ing abilities.
If I haven't got the chipset/CPU architecture decision wrong, then the only variable I can see is the motherboard. The Z170 range seems to have better quality MB's at cheaper prices. I was very impressed with my Asus ROG Crosshair V Formula-Z board, and with the Z170's above, liked the look at the Asus ROG Maximus V Hero board...
The Asus ROG Rampage V Extreme board is a lot more expensive than the Asus Strix X99 board, but which would you recommend? Is the Strix worth taking for the cost saving? Is the Rampage worth the extra? Or is one of the MSI boards worth using instead?
Thanks in advance for anyone's advice!
- Z170/Skylake.
- X99/Haswell-E.
- X99/Broadwell-E.
- 1 x OcUK Tech Labs Skylake Z170 Pro Gaming PC Configurator = £1,959.86
- Processor:Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - OEM
- CPU Cooler:Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler (CW-9060025-WW)
- Motherboard:Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard
- M.2 Solid State Drive **For Operating System If Selected**:Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV512HDGL-00000)
- Solid State Drive 1:Unwanted
- Solid State Drive 2:Unwanted
- Mechanical Hard Drive 1:Unwanted
- Mechanical Hard Drive 2:Unwanted
- Optical Drive **Please Check Chassis Support**:Unwanted
- Graphics Card:Asus GeForce GTX 1080 DirectCU III OC Strix Gaming Aura RGB 8192MB GDDR5X PCI-Express Graphics Card
- Power Supply:Corsair RM Series RMi 1000 '80+ Gold' 1000W Modular Power Supply (CP-9020084-UK)
- Sound Card:Unwanted
- Networking:Unwanted
- Operating System:Microsoft Windows 10 Pro 64-Bit DVD - OEM (MS-FQC-08929)
- Security Software:Unwanted
- Keyboard:Unwanted
- Mouse:Unwanted
- Monitor:Unwanted
- Gaming Headset:Unwanted
- Speakers:Unwanted
- Memory:Ballistix Sport LT 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - White (BLS2C8G4D240FSC)
- Build Time:Standard Build Systems - Dispatched within 7 working days
- Case Lighting:Unwanted
- Case:NZXT H440 New 2015 Edition Case - White & Black
- Gaming Chair:Unwanted
- Graphics Card 2 (SLI/Crossfire):Unwanted
Total: £1,973.96
- 1 x Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail= £299.99
- 1 x Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler (CW-9060025-WW)= £89.99
- 1 x Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £184.99
- 1 x Thermal Grizzly Kryonaut High Performance Thermal Paste - 1 Gramm= £4.99
- 1 x Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV512HDGL-00000)= £179.99
- 1 x Asus GeForce GTX 1080 DirectCU III OC Strix Gaming Aura RGB 8192MB GDDR5X PCI-Express Graphics Card= £659.99
- 1 x NZXT H440 New 2015 Edition Case - White & Black= £84.95
- 1 x Corsair RM Series RM1000X '80+ Gold' 1000W Modular Power Supply (CP-9020094-UK)= £144.95
- 1 x Ballistix Sport LT 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black/Grey (BLS2C8G4D24= £68.99
- 1 x Microsoft Windows 10 Pro 64-Bit DVD - OEM (MS-FQC-08929)= £119.99
Total: £1,838.82
- 1 x Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K)= £335.99
- 1 x Asus Strix X99 Gaming Intel X99 (Socket 2011) DDR4 ATX Motherboard= £268.99
Total: £1,958.82
