- 20 May 2009
Which way to mount the psu? say if it is in the bottom of the case - would the fan be pointing upwards into the case? Thanks!
Oh lord no. Fan out the back for sure.
Ok so i mount it exactly like this guy -
http://www.youtube.com/user/tobleroneuk#play/uploads/39/UBEFIJmg-fk
01:12 mins for a close up...thanks!
That space they leave you at the bottom is not nearly nough room for a good supply of air to the psu.
Face the fan upwards, it pulls the air in from the case - through the psu - and out the back of the psu acting like another exaust fan.
/Thread![]()
