I'm having a hard time justifying spending $300 on a Thrustmaster wheel or $350 on a Mad Catz wheel due to having their gear in the past and it being cheap crap. I used to use a G25 and Fanatec Clubsport pedals back when I did a load of rFactor sim-racing and that together cost around the same as the current XB1 offerings and was substantially better quality.
So, is there anything else I could be looking into? I'd say $300/$350 is the limit so I can't go for the latest Fanatec gear
It'd be nice if it also worked on PC too as I'll be getting back into that at some point in the future.
Do any of the current systems come with load cell brakes, etc?
If not I guess the Thrustmaster will have to do.
Cheers!
It'd be nice if it also worked on PC too as I'll be getting back into that at some point in the future.Do any of the current systems come with load cell brakes, etc?
Cheers!
