Which white cables do I need for new pc build?
  • Thread starter Thread starter Deleted member 251651
  • Start date Start date
D
Hi,
Need some help to find which cable I will need, basically building in white lian li evo case with dark power pro 12 1200w psu. I do not need the 24 pin or gpu cables, as i'm planning on buying the lian li argb strimer cables. So which other cables will I need? I want them to be all white apart from connectors which need to be black as going in a black x670e hero motherboard. I think i need 2 8pin eps connetors for the cpu....? what other white cables will i need and which do you guys use/reccomend? I dont think there is any point in buying a full kit as I wont use all the cables and just waste money? Cable mod do not mension comptibility with dark power pro 12 either? Which cable will I need to use for the front panel usb charging capability? Are there any other cables which are generally upgraded for asthetics?
Does the front panel i/O charging require a 6 pin atx 12v extension cable? If so where can I get this from as I cant find any?
TYI
Is this the right cable? I have ordered this from overclockers, but not sure if its right one...?
or do i need a 6 pin to sata lead? is there a diffence between these cables, I saw somewhere need to connect the 6 pin on my motherboard in order to use the usb c 60w port for charging?
if they are just extensions
doesnt matter which you use
if connecting them directly into modular psu
then yes very important you get correct ones for the specific psu
will your 2 x cpu connectors actually be visible?
mine certainly arent as got radiator at top of the case
for the front usb-c charging i used a pcie 8 pin that allows only using 6 of the pins
so for an extension i would look for 8 pin that can split into 6+2 pins
failing that i would try the extension you showed
Don't they have different pins, or slightly different connectors to each other?
Yes, 2x cpu connectors will be visible a little in top left corner.....oh true........ What fans are you using? Are you using 2 sets of fans push/pull on radiator? I will only be using one set exhausting air by the Lian li sl120 infinity on a Z73 Kraken AIO 360. I think they will still probably be visible a little
You mean something like this.... https://www.overclockers.co.uk/silv...-pin-25cm-pcie-extension-white-cb-016-sv.html
Thanks for your help, greatly appreciated!
1 set of standard 25mm fans
no push and pull
and my pc is sitting above floor level
i still dont see my 2 x 8 pin cpu connectors
if it was on the floor even less likely to be visible
and yes at the psu end the pin outs can be different
but extensions dont alter whats at the psu end far as i am aware
none of the extensions carry any sort of warning that they are only
suitable for specific psus
whereas if you look at full custom cables they will carry a warning
yes those sort of 6 + 2 pin ones
