Which wifi extender do i need
10 Sep 2003
Good morning
I have a Draytek 2760n modem/ router and I am looking for a wifi extender / booster but am not sure which one to buy. I was looking at the netgear 11ac 1200mbps dual band extender and also the same model but dual band gigabit 802.11ac, but am confused as to what is right for my router. Hope you can kindly help, many thanks. Am using standard BT broadband
Is running a cable from your router to another wireless access point feasible?
Externders and powerline aren't the most optimal way of doing it. A hardwired access point will give you a far better connection.
Wifi extenders are trash and should be used only as a last resort, if a hard wired AP is out the question then you should consider Powerline or a Mesh based system.
